cycojon
addicted to my superjet
- riverside ca
i have searched, seems like sxr threads die off real quick around here these days... haha!
my buddy has and 03 SXR, wet pipe and stock head. were thinkin about doing dual cooling.
should i set it up like my sj;
one line from pump to "T" then from "T" into two spots on the exhaust manifold. then two outlets off the head and overboard with two pissers.
one line from the pump to the bottom of the head pipe then out of the top of the head pipe to a "T" from the "T" overboard with a pisser, from other side of "T" to a FCV to a restrictor then into the stinger.
there will be 3 pissers.
questions, do i need to drill another hole in the stock head or can i use the two outlets that are already there.
also, do i need to use a 1/2" ID water line from the pump to the motor? i seem to find people saying you need a larger water fitting off the pump, is this true? on my SJ i used the standard 1/4" NPT fittings on the pump, exh mani and head.
so will this work ok on an SXR? or should i post this on PWCT? haha
by the way, im workin on him to get a SJ... i think just a few more rides on mine and he will be sold, he is real close now! :notworthy:
