SXR SXR pole spring tensioner
which one do you guys prefer ?
the r&d is adjustable which is nice, but do i really need it?
i would like a handlepole spring tensioner that allows me to retain the useage of the stock pin (to hold up the pole while servicing) i saw an older post that showed the riva tensioner required slight relocation of the pin, so not sure if they all work this way or not.
your input is greatly appreciated.
USA
the tbm racing one is great, just slides under the spring arm, bolts down and you get to reuse the stock pin, it's pretty much weightless. little pricey but great quality.
