SXR sxr sensor question
montreal
heres my 2010 sxr,anyone here can explain me what is the green conector and the litle sensor on the e box,i circle it in black,in a little square.thanks!
Idaho
That is your ambient temp sensor. It will control the timing based upon the air temperature in the hull. That is the connector that gets jumpered with the wetpipe install to advance timing.
