Hi guys,
I thought I would run this by you SXR guys in case you've seen the problem before...
Setup is a stock SXR engine with wet pipe, Jetinetics flywheel, VF2 reeds and Hooker 11/17 prop...Have dual cooling from the pump with one circuit running to the head pipe and dumping overboard, and the other running into the manifold and out the head dumping overboard.
The problem we are having is that the engine will only rev to 6050 rpm, and nothing more. It revs straight to 6050 against the dock and doesn't move from there.
Jetting is per fpp specs, but I have dropped the main down to 150 and adjusted to the point of the engine making more heat and no more rpms, so I'm thinking the problem lies elsewhere.
The ski hits good off the bottom, but just will not rev. We've switched out the entire e-box for a bog stock sxr that runs perfectly, but we have the same issue.
I've checked all the obvious things, but am open to suggestions.
Anything come to mind? Prop pitch is the one thing that may be an issue, but I would have thought that the hooker 11/17 would still turn more rpms than this.
Cheers.
Leigh
Cheers.
Leigh
