TBM Flywheel thoughts
it seems that youd benefit the same way as total loss as far as weight goes, but you wont get the multi spark discharge of msd. :dunno:
Ohio
I never understood TL. I want a charging system.
Dangit man that thing is sick!! I wonder why it is 100 more than the SXR alum charger.
skinnyman
YOU CANT RENT MY SKI
Dallas/ToyBox
I have one just have not installed yet
Mine was 2.3lbs
If you are running advent you need to talk to Tim
It is a really nice flywheel and Tim is great to deal with
Katie
Way cooler than Mark44
Union, Missouri
Yeah-I am not messing with TL I would just do this. Why have the hassle in my opinion. I believe a couple people bought this flywheel used from skiclinic post your thoughts!
QJS
X-
GONE
There is much more to total loss than flywheel weight, the timing curve can be adjusted which is probably more important than flywheel weight,particularly on a high performance engine.
Chris.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
the adjustable curve is very beneficial too the TL system too, I would think?
you can ad massive ignition advance down low, and pull it out in the upper RPMS to have good snap and still not blow things to hell on long high RPM runs.
Watty
Random Performance
Australia
I'll take the total loss thanks...
I don't see where the hassle comes from. You attach the brain to a board, bolt on your pickup plate and flywheel and run some wires...For the gain it gives, it's well worth it.
crammit442
makin' legs
here
EXACTLY!!! Less hassle than charging systems IMO.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
I prefer the automatic charging of my ski personally, but if Total Loss systems were CHEAPER, and the brains more reliable, I would run one.
I had an old style, single pickup digital brain, and decided not to use it, didnt want to charge batteries, and was afraid the brain would die on me.
I would LOVE to have a lighter charging flywheel, and more control of the timing curve.
but it just isnt worth $600 to me.
Mark44
Katie's Boss
100% one place
I wouldn't want to loose my charging system and from all the headache threads on TL and brains going out I think the 500 dollar fly wheel would be a better choice for me.
Mark44
I think this would be a much better alternative for salt water riding..... IMO, unless your trying compete in freestyle or race, TL is way overrated. Charging before every ride is just one more thing to do before hitting the water.
I would like to here some reviews of the TBM vs a OEM lightened, if anyone has done any back to back testing.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
If stockers weigh 61X flywheel 3.610 lb and 62T 3.7436 lb
and you can safely take off 0.5 lbs of them for $65 or so.
you have 3.1 or 3.2 lbs for $65 vs 2lbs for over $600?
I know 1.1lbs is alot when its spinning 8000rpms, but man thats pretty expensive performance!
