Freakrider
X247
- Tampa Bay area
sj762 designed a test today to check if cooling lines are leaking inside a carbon hull and under the tray. The lines in the pump area are blocked off with a bolt capping off a cooling hose. Inside the hull a water hose is hooked up and the lines are put under full pressure. Hull is propped up in the front and drain plugs open and monitored for any leaks. Whatcha think ?
