- Ontario Canada
Hey folks, bit of a story so bare with me.
Last spring i built my aquabot and it always had some type of hesitation, whether it be electrical or fuel. Tried everything under the sun with my carbs setup wise and would never completely get rid of the issue, even tried switching the carbs with my friends to see if my carbs were somehow bad, no dice. So i thought maybe it was electrical, tried switching out my enhancer with my stock cdi, nothing. Tried the coil, voila! thing roared to life and ran perfect! so i went ahead and put my msd back in and went to the lake the next day, back to running like chit! At this point im stumped, i replaced the stator as i added a plug to mine and maybe thought that was my problem, seemed to get a little better but no where near what it was. also tried a another new coil with no luck.
The problem is best described as electrical break down, i have it jetted now to try and compensate for it and its ride able but there's definitely more there. Im lost on what else it could be thats causing my problem, i also added a ground wire from the battery to the ebox.
So to recap, ive switched coils, stator, cdi, carbs. went over all connections in the ebox, tried disconnecting the s/s switch. all have no effect in getting it back to where it was before after the first coil switch.
hpe 819, stock charging system, msd enhancer, b pipe, a/m 44s
If anyone has any other ideas it would be greatly appreciated!
