I found a super jet in Madison IN & I could not pass on a jet ski named the "Panty Dropper". My wife thinks I should change the name. Anyway, Ski is not running very well. Rebuilt the carbs and checked the compression. Both cyclinders are 150psi using an ADA head. After another water test with no luck. I pulled the head and the piston are black. The squid before me did NOT run dual cooling on the factory pipe setup correctly so we have a heating issue with baking oil.
Question:
Do you guys think I should do a rebuild based on the black pistons of just fix the remaining issue and give it another try? Thoughts...
Question:
