- wichita, ks
I decided to start a build thread after cracking the hull at lsfr. The ski is going to be House of Kolors Hot Pink pearl across the top. The handpole is going to have pink lettering also that says save the tatas, around the lettering it will be black along with the bottom side also. I started off with this ski about 2 years ago, new to this but learning as i go. Last time i rode it was like 2 weeks ago at surfside with the rest of the fellas at lsfr. Ended up cracking the back side and as we came back into town i rode on a river in houston and subed it and broke 3 motor mounts and the coupler. So for now i will be trying to rebuild the parts broken. So far i need motor mounts coupler and might be trying to get a b-pipe. As i got home i decided to start pulling turf. Turns out it wasnt as bad as i thought. Decided after knowing that i cracked it and it was leaking water i figured it was probably waterlogged also. So i decided to cut the tray using a oscillating tool. Worked great used a putty knife for about 2 days pulling foam. Talk about a pain. So yesterday i decided when i got home that i wanted to cut it down. Being the first time i have done this it seemed kind of hard. Once i got into doing it thought it went very well. So heres the pictures to where i will be at right now. From here on i will be reinforcing the bottom under the tray. From there on out Im not sure yet. Any other suggestions as I go
Are appreciated. Thanks for looking also. Color of the bike is my buddies stunt bike and that will be the color i will be going with.
