- Marion, Ohio
Having problems with water filling up your lay-down style pipe and getting into your expensive motor? Can't fit a tall waterbox into your hull but still want protection against water intrusion? Don't want to worry about rubber flaps degrading and tearing off? This might be the waterbox for you!
Designed to prevent water from rushing back up your exhaust tube while maintaining a compact size, this waterbox is laser cut and CNC bent from corrosion-resistant 5052 aluminum before being TIG welded. As soon as water starts to flow back into the box, the hinged aluminum flap closes tight against the baffle, significantly limiting flow back into the box while allowing exhaust gasses to flow freely once you're back on the throttle.
$269 + Shipping
Waterbox Backflow Tests:
This video shows a couple of the bench tests performed to simulate hypothetical situations that could cause significant amounts of water to rush back into the exhaust. I used the popular PFP and TNT waterboxes as benchmarks.
$269 + Shipping
