Thin Head Gasket
I want to run a thinner head gasket on a 701. What are my options out there?
I have tried a 760 gasket but I am having problems making it seal properly.
I have an oem head that was machined for higher compression but need to reduce the head gasket thickness. Squish is too high (around 0.055-0.060) and compression is lower (160) than I would like.
Im thinking I may just switch to an ADA head. That way I can dial in the compression I want, and can easily take on and off....
