throttle cable?
SuperJETT
none
If you flip the carbs around and remount the cable on the front, you're fine. With it on the rear, you can barely get it there.
Keith
Landlocked
Nebraska
With it mounted on the rear you will either have to run the stock cable up and over the fuel tank or get the pre-96 cable.
SuperJETT
none
MikeB/Mako Mike said:
I got a 97 Sj with a minus 2 pole and used the same cable.carbs are on backwards.Had to make a bracket for the cable at the carbs though.
I drilled holes to mount the oem bracket on the front of the manifold just like it was on the rear.
