SX/SXi/SXi Pro through hull trim tube on 750 sx PLEASE HELP.
i am putting a x2 trim set up on my 750 sx and i need a tube through my hull to run my cable so i dont have to use my stock syphon bilge,my question is,if i drill a hole strait through the hull directly above the 2 factory tubes(bilge and water intake nipples) will i run into any of the stock tubing with the drill bit,the X in the pic shows where i want to drill the whole,any input would be very appreciated.
You'll be fine there. Just angle it to the right a little when drilling from the back. The cooling line beneath your mark bends up and over the pump tunnel.
Sent from my DROIDX
