- Palm Beach, Fl
We just received a fresh shipment of levers in!
These levers are so trick, just what I wanted from a lever being 1 finger style, there's no mistake grabbing the throttle on accident coming down from no handed tricks. You can adjust the pitch of the lever by loosening 1 bolt, unlike other levers where you have to remove the entire lever to get to the adjusting bolt. These are made to work with 6mm Yamaha Cables and do not require a adapter.
http://www.thrustinnovations.com/th...-innovations-billet-throttle-lever-p-907.html
