THRUST
ThrustInnovations.com
- royal palm beach florida
http://www.thrustinnovations.com/bars-and-steering-c-32_35/ti-ez-steering-adjustable-p-623.html
Thrust innovations TI ez steering adjustable
Not to take from other manufacturers on the market, but we have created the most advanced steering system to be offered to the stand up watercraft industry. This product like our trim shows Thrust attention to detail and innovation at it's finest. First off, the steering is made from 6061 billet aluminum for strength, then hard anodized to ensure a finish to last a life time. Going deeper into the components you will find the world first adjustable bar height system. Our unique adjustable pivot allows the bar height to be easily adjusted, with out sacrificing the strength of the unit. With a 5mm hex head you can simply adjust the bar height to your preferred bar location, offering a -45 degree to +45 degree bar height. This patented pending system has been tested over the last two years and has proved it self to many pro riders around the world. After gathering feedback from riders there was a demand for a low maintenance system, no o-rings and no bearings to fail in the middle of a ride to ruin your day. With that in mind we brain stormed and came up with the first ever patented sealed ceramic bearing system to be offered to the pwc industry. Our patented bearing set up is unlike any other system on the market, it's not a direct copy of the 90's steering with a twist on it. Our steering has least amount of resistance and is also the lightest fat bar system on the market. There are two sealed ceramic bearings wrapped around our 30mm steering post, this it were the entire system operates around. This will insure low maintenance, high strength, and the smoothest steering to date.
