Thrust Pissers with PFP pipe ran wet
anyone came up with a flush kit for the thrust pissers? Have dual cooling then the pipe is ran wet Inside the ski is three of the quick connect sea doo flush fittings but did not come with the ski when i purchased really dont want to spend 60 bucks for three kits just to have to two of them up and make a custom setup?
I made one out of aluminum that worked via a grinder and some clever smacks with a hammer to make a oval out of them. They got you a little wet, but the job got done.
Thrust should offer a flush kit for thier pissers, cool design, but hard to back flush.
Tuscaloosa, AL
I just pulled the lines off the head and had a 3rd line that had a "T" on it that I hooked up to the headpipe, water flowed both ways. It was a pain but worked.
Bay Area
i made a dual flush with some stronger plastic tubing that you have to force into the pisser but it works! yes Thrust should make a kit
