Thumper
IKSTEJ
BOGIE
Region 7
Well here it is, after intense planning, and design here is the new XSCREAM seven port Powervalve Cylinder.
Comes out of the machine with our exact porting specs.
Cases are CNC machined,... precisely matched to the Cylinder.
This engine is 90mm pistons on a +12mm lightened crank.
XSCREAM designed sleeves.
New XMETAL Head design.
It currently has a Boysen intake with 48mm Freestyle Novi's, but the 49mm Full Spectrums are on there way.
Custom Wiseco pistons
The new P.F.P.....or (EME) (Yamaha) Pipe. (Were able to run a 2 gal Jazz tank with the pipe)
MSD Total Loss
Our goal (not only for this package) is to have shortblocks on the shelf for immediate delivery.
That is our current status with our smaller configurations, and will be for this setup by mid July.
All complete engines packages always have and always will be shipped accurately timed, and jetted.
Just add battery, plugs, and Fuel :) & balls (
RadRat
www.proridermag.com
McDonough, GA
Hehehe....glad everyone likes my motor. It will be debued officially at the 2008 National Championships although I have about 3 shows to break it in within the following week....
All that needs to be said is one word...
XSCREAM!
Tuscaloosa, AL
XSCREAM!
Like your pole??
gonna rename you "Wishbone"
crammit442
makin' legs
here
Are you saying these are billet cases? Or are they just CNC matched and machined OE cases? Either way it looks nice!
Hey Pat, when your installing Ratti's new pole you can throw that in the hull also!!!!!!!!!!!!!
i hear that is ratti's new motor.. now pat just has to build a new pole:eek:mfg:
pat's dis-claimer talks about uncontroled erections not broken poles (ouch):bananalama:
wow that is a simple clean look with some special chuckie sauce:starwars:
guess i'm a little late..
