Tigercraft e box power cables
How's superjet cables work out on tigercrafts with the ebox mounted next to the carbs?
Am I best to get custom length cables?
I have a small collection of battery/starter cable lengths. If you get me approx measurements and quantity I can probably set you up really cheap.
be_lain
Currently sending it
Oregon
They are a little long. I just finished my sv1 and put the ebox right next to the carb. Cable from ebox to starter was alright but the battery to ebox was way long by like 12”. I am going to switch to a raider battery cable (shorter) next time I pull my ebox apart.
You can get all the supplies from bestboatwire.com and make your own custom cables. It ends up being cheap and they are the correct marine wire and connectors. Ben doing it on most of my builds.
tinned wire on ebay, 6awg, with marine ends and shrink tube. Ive done 4 skis so far, with a extra engine ground and a ground for the ebox, for less than 40 dollars in materials
Tyler Zane
Open Your Eyes
It worked out to 5 feet for ground, 40 inches for starter and 20 inches for batt POS.
That's running them around the back of the engine to the starter.
I ended up getting jss to make them. I could of done it myself but I'm so swamped right now it was easier to get them made. Rebuilding this entire ski has been a huge pain because the last guy was a total hack job.
