tntsuperjet
- Georgetown ca
Here the tnt x2 chamber, we did testing with a ported 750 small pin cyl with 750 big pin cases, stock pump, 9/16 prop pump gas comp stock ignition, modified mariner water box with all 2" pluming.
Boat ran 53.3mph and accelerates hard View attachment 341348
I have one on my 650 X2, fully ported with a single 44 solas 16 no waterbox, ada head with 230 PSI and i got 50.7, ski hits hard!! Time advanced all the way.The x2 chamber will be available next week.
I am making 4 of them.
Tnt performance engineering on Facebook.
I have a super sport pipe I am installing in my X2 with a modded 701. What water box do you suggest. I am assuming 2" inlet and outlet? Thanks.Here the tnt x2 chamber, we did testing with a ported 750 small pin cyl with 750 big pin cases, stock pump, 9/16 prop pump gas comp stock ignition, modified mariner water box with all 2" pluming.
I was using the hx box, now I just don't use a waterboxYa I have seen the HX box numerous times. I may just go that route or an AM one.
Still have the waterbox? If so, consider selling?I was using the hx box, now I just don't use a waterbox
Sent from my SM-N960U using Tapatalk
