hey guys well this is my 1st total loss 2nd hand unit analog msd.
gets it all in there, and it fires sweet down to the water.
had a 5min go then a mate had a 5min go after that no starty.
pull it out play with the wires, check spark only very weak not hitting all the time.
so i've come home had a look on here & a similer problem was not grounded properly, so i've add a big ground st8 to the mounting plate from the battery then thinner wires to each of the bits. (before i only had a few bits going to the intake manilfold and my main -neg was on the back of the starter motor)
now still no sparky not even a weak one.
i have one green trigger wire spliced to the stop switch/lanyard the other from the stop switch goes to ground, if i hit the stop button (same as hitting the two greens together) i get a hot spark.
so the coil works.
the led on the brain flashes as i crank it so the pickup must be working.
i have to admit i haven't checked the air gap its nxt on my list, but im pretty sure its right.
would the brain still flash if the air gap was wrong?
any1 have any other things i might try (i know go check the air gap)
so the coil works.
