Total loss enclosure material?
So I got an old msd 4270. I want to Put in an enclosure. I welded an aluminum box up and made a lexan front it will be water proof but now I'm noticing all these msd boxes mounted on com posit plates or lexan. The ski I took it off of had it mounted in the plastic ebox cover. So my question is. Can I mount it to an aluminum box? Are there any guide lines to mounting up this unit also any tips or tricks? I wanted to put all the electronics in a water tight enclosure. Will it hurt to have it mounted on the aluminum it will all be grounded. Also I would like to know where I could find some through panel connections to run so I can keep the coil in the box and hook the coil wires up on the out side?
Christian_83
Xscream
Denmark
Yes, thats fine with aluminum housing. Many freestylers mount them to alu or carbon plates, in carbon hull (carbonfibre is conductive)
Be sure to make a GOOD ground for everything, you can never get to much ground :)
Other option, if to find a IP67 electrical enclosure to put it in, i did.
