I've got a fairly interesting situation here with my total loss setup. I had to drill and tap the mounting holes for the trigger plate and they can only go in two spots so that's a no brainer. The problem is I can only set the static timing to a max of 15° which means my max static timing advance is only 10°... Do I need to drill and route out the trigger plate or am I missing something?
