- Downers Grove IL
This is my first total loss system. I originally had someone setting it up for me and it fell through. I am a bit overwhelmed by this project. I think i am making it a bigger deal than it is because i have heard of so many people having issues with their systems. I am going to knock out the wiring tonight. This is my first time doing any type of wiring and have no electrical knowledge. There are a few questions still and would greatly appreciate any help.
Questions on bilge
- for a bilge I just want to split the violet wire coming from the brain to the shifty mod and add a fuse right?
-What connection should I use to split it?
-Where can I get the proper fuse and holder?
Solenoid questions
- how are people mounting the oem yamaha starter soliniod? It just has 2 slots in the rubber.
-Am I blind I don't see it being marked as positive and negative?
-The wires that come connected are the ground and the coil wires in the diagram right?
Ground questions
-the grounds from both coils and the starter soliniod and the shifty mod will all run to the starter ground?
The brain is grounded via the battery?
Mounting question
What is the best way to mount the total loss plate on a firewall (rickter edge) without drilling through the firewall?
Capping unused wires
-what is a good method for capping off used wires?
Again thanks so much for any help. I am thinking of making a video of my setup if there is any interest.
Questions on bilge
Solenoid questions
Ground questions
Mounting question
