SOLD TPE 1105 need new nikasil & 1 new conrod. 3000 euro
Christian_83
Xscream
Denmark
READ entire post before replying - thanks
TPE1105 that i just Rebuild, with new nikasil, new pistons. nikasil made by powerseal in Holland. Everything checked out, ring gab, presssure test. Etc. After first fire and 20min ride compression was still 15psi different on cyl 1 vs cyl 2. Turns out the final diameter bore is 0.150mm to tight. So will need new nikasil. Use same (20min Old pistons) The ADR 10mm crank in the package needs 1. New con rod, and a small weld job on key way. Cases and opened for big reeds (these can be bought with the setup) Located in Denmark europe. Shipping world wide on buyers expense is possible.
PM me for video of engine running and pressure test.
3000euro as it is
5300euro with the work done, ready to drop in and run
Also posted on the diffrence facebook jetski pages.
269754182_10161427613254992_2074517959603581837_n.jpeg270185717_10161427613244992_8521515125635481730_n.jpeg
