I just got a free trailer from one of my parent's friends and i need help selecting seals.
The trailer is a 15-year old mejier(yes the grocery store) trailer and one of the bearings was bad, so i replaced it. However, the axle/ hub are metric and its tough to get any of the seals.
I the ID numbers are as follows on the seal ridge SDA 579 VB2 31(mm inner diameter) 52(outer) 7(ht) it is a single lip seal
I found a few seals which might work but arent exact
a double lip seal with 30 inner 52 outer 7 ht
a double lip seal with 32 inner 52 outer 7th
a single lip seal with 31.75 inner 51.9938 outer 9.35 ht
Which would you guys buy? or should i keep looking? They dont make 31mm anymore. I would love to buy a whole new axle, but $20 vs 140...
