Hey guys, I'm in the process of improving my ski trailer and was considering going to a winch instead of the bow stop with a pin. So far, I've lengthened the tongue to make enough room for a bin on the front. While I'm doing this, I have the option to switch to a winch since I'll have a new welded bow stop. The reason I'm considering this is because I switched from PVC bunks to 2x4's with plastic sliders, which are very slippery. I had difficulty holding the ski that far up on the trailer as I tried to slide the pin in. Ended up having to back very far into the water in order to float the ski over where it needed to sit. Anyway, in order to make this happen I would need to drill through the hull to mount a U-bolt on the ski for the winch to hook to, and would need to rig something up for stopping the ski from sliding forward. Can anybody give some opinions, or send some pictures? You can see my before and in-progress pictures attached. Thanks in advance
