Trim installation question
Trevorbm
“Only full sends, we’ll fix it later”
Xenia Ohio
When installing the cable. What’s the best way to install it through the hull? Is there a fitting I can get similar to the water fittings to make it water tight? Would like some advice before the job. Don’t really want to drill a hole and slap on some silicone lol.
VXSXH20
Sionis Industries
Mid-Atlantic
if you already have a tube in the hull for a cable or extra cooling line you can use a rubber boot with a reducing end. Thrust innovations has them or check with jetmaniac.
If you have no trim tube you can try searching and looking into a cable gland fitting.
installing a proper tube thru the bulkhead and tray to the pump cavity is the best course of action. Most trim kits will have a L bracket that bolts to the pump reduction nozzle to secure and operate the cable
Trevorbm
Xenia Ohio
any info on where to get the tube or how to install it through the bulk head?
