Trim Systems and parts from JetManiac
Thrust Trim Systems
Thrust EZ-flo Pro 144-148mm complete trim system 699. -on backorder from Thrust
-Includes Thrust billet pro trim ring, Thrust trim cable, Thrust MX trim lever, stainless hardware, Thrust trim reduction nozzle 86.5mm bore, and Thrust trim aluminum steering nozzle.
Thrust EZ-flo Pro 155-160mm complete trim system 759. -on backorder from Thrust
-Includes Thrust billet pro trim ring, Thrust trim cable, Thrust MX trim lever, stainless hardware, 155 trim reduction nozzle, and Thrust trim aluminum steering nozzle.
Thrust aluminum trim steering nozzle 159.95
(for all sizes of Thrust trims, 89.5mm bore)
Thrust aluminum trim reduction nozzle 165.
(for 144-148mm pumps, replaces 62t red. nozzle, works with many other trims, 86.5mm bore)
XMetal Trim Systems
XMetal/XScream OG Trim System 425.
Includes:
-Stainless steel electropolished trim ring
-Easy access pump mounted billet cable mount
-XS heavy duty trim cable
-Odyssey Trim Lever
-Stainless bushings and bolts for mounting to Raider style Exit and Steering Nozzles
-Stainless ball joint end and extension for Steering Cable
-Trim return stainless spring
*Plug n Play 30 degrees of trim without any modification to supplied parts.
*Yamaha Raider style nozzles require minor sanding for trim ring clearance.
Complete XMetal Trim System 689.
(includes OEM trim reduction/exit nozzle and OEM trim steering nozzle, for 144-148mm pumps)
XMetal 155mm billet LS10 double backie trim system $1,149.
small bore for 155mm pumps
large bore for 160+mm pumps
RRP trim systems
The RRP trim system is a super easy top pull trim system and was designed to be effortless and allowing for better rider control during maneuvers and tricks. The trim design features increased water flow while minimizing pressure loss during turning and trimming, this was achieved with a all new trim ring design that features a tight clearance between the exit nozzle, the trim ring and the steering nozzle. The top pull mounting point on the trim ring is slotted to adjust the amount of trim the rider desires. Complete trim kit includes RRP reduction nozzle, RRP trim ring, RRP steering nozzle, trim cable, lever, and hardware.
RRP 144-148mm complete trim system 699.
Complete trim kit includes RRP reduction nozzle, RRP trim ring, RRP steering nozzle, trim cable, lever, bracket, trim cable end and hardware.
RRP 155mm complete trim system 799.
RRP 155 aluminum steering nozzle 144.95
Trim Reduction Nozzles
Thrust aluminum trim reduction nozzle 149.90
These metal reduction nozzles have been newly taper-bored to 85mm. Limited availability.
The nozzles have also been refinished and are ready to install.
They are designed to increase water flow through the pump to help with low end freestyle performance.
144-148mm 62t Bored trim reduction nozzle 169.
(for homemade CATS, Xmetal, Thrust, and other trim systems)
(without stock siphon bilge fitting)
5deg up Bored 144-148mm trim reduction nozzle 169.
155mm Bored Reduction trim nozzle 179.
5 deg up 155mm Bored Reduction trim nozzle 179.
Trim Steering nozzles
62t SJ 08-20 new OEM Yamaha trim steering nozzle $114.95 sale 99.80
or
62t SJ 08-20 clean, used OEM Yamaha trim steering nozzle 49.95
Thrust trim 144 steering nozzle (New OEM) $72.90
OEM trim ring 19.90
OEM trim ring bolts and stainless bushings 7./set
OEM steering nozzle bolts and stainless bushings 7./set
Pro Tec aluminum trim steering nozzle 169.95
Trim replacement parts
Trim Levers
XS MX trim lever 39.90
*includes machined adjuster to fit XS trim cable
Thrust MX trim lever 39.90
*includes machined adjuster to fit Thrust trim cable
Thrust billet trim lever 89. (backordered from Thrust))
Thrust brass trim lever cable adjuster 12.95 (for billet lever)
RRP billet trim lever 84.95
Trim Cables
Thrust replacement EZpull trim cable 99.90
* Fits original EZ and pro EZ pull trims
XS Xscream/Xmetal replacement trim cable 118.79
* For XS OG and XS LS10 trim systems
RRP replacement trim cable 109.70
* Also best choice for CATS/homemade straight pull trim setups
5mm threaded trim cable extension 20mm -stainless male to female 10.95
5mm threaded trim cable extension 30mm -stainless male to female 10.95
2 pack (or 1 of each) 8.95/ea
RRP trim cable heim joint with slider 49.89
* for trim cable to trim ring attachment, saves trim cable bending fails
Trim parts
Trim return spring -stainless, long 8.95
(standard length for XS, Thrust)
Trim return spring -stainless, medium 8.95
Trim cable to hull tube rubber boot seal $8.50 or
2 pack 5.95/ea
4 pack 4.95/ea
(std size fits approx 5/8" OD trim tubes)
(larger size fits approx 3/4" OD trim tubes)
XMetal trim steering cable extension and heim joint 39.90
Thrust trim steering cable extension and heim joint 29.90
Heim joint 'no slop' stainless steering cable end 5mm 19.95
Cable extensions
Steering or trim cable extension 20mm/0.75" -stainless male to female 5mm threads 10.95
2 pack 8.95/ea
Steering or trim cable extension 30mm/1.2" -stainless male to female 5mm threads 10.95
2 pack 8.95/ea
*extensions fit std. SJ and B1 steering and trim cables
XMetal replacement stainless trim ring 179.95
OEM 62t trim ring (clean, used) 19.95
Thrust trim stainless trim ring to reduction nozzle bushing
Thrust trim stainless trim ring to steering nozzle bushing
Xmetal trim stainless trim ring to reduction nozzle bushing
Xmetal trim stainless trim ring to steering nozzle bushing
Thrust Trim Systems
XMetal Trim Systems
Includes:
-Odyssey Trim Lever
RRP trim systems
or
OEM trim ring 19.90
Trim Levers
Trim Cables
Trim parts
2 pack 5.95/ea
4 pack 4.95/ea
Cable extensions
2 pack 8.95/ea
2 pack 8.95/ea
