If you don't mind my asking, what do you do/did for a living?
I did a lot of reading b4 porting my cly. One thing that showed up a lot is "do not touch the top of any port(for bottom)".
If the home porter will follow that rule it will help to insure good gains.
Well I dont make a living doing any engine work if that is what you are getting at
I have read read butt loads and learning about the engineering of 2-strokes is/was a hobby. Good reading: Gordon Jennings, two stroke tuners handbook (old), and Gordon Blair, The Design and Simulation of two stroke engines, (not so old). Blair has come up with the formulas that pretty much all modern engine modeling software is using.
Yes, it is true about not raising ports any to maintain good bottom end delivery in almost all cases, BUT the bottom end delivery would still be improved to slightly raise 1 or 1 side of the x-fer ports to match them. This matching cant be done unless you have a right angle grinder that can get at the transfer and not bugger up the entry angle... Most of the sleeved cylinders that are common in watercraft engines are reasonably matched height wise. Any time a cylinder has been bored, the boost port needs some attention because of its steep entry angle. On edit: Of course there is nothing to match on the boost port, but to maintain original port timing the boost port need cutting after boring, that is not raising it, but raising it back to factory spec post bore, the bigger the big bore, the more the boost port need raising to get it back to spec.
