- Austin, Tx
Bear with me, I searched and came up with nothing.
I want to add an inline silencer to my exhaust routing under the tray (I hate loud skis). The silencer i picked up has roughly 1 3/4" OD with the ID being slightly smaller. Im nervous to run this one because once I button up the tray I do not plan on opening it ever again. Im using 2" sch40, and it just so happens that the 2" to 1.5" rubber couplers for PVC fit the 2" sch40 and silencer perfectly (since 1.5" PVC OD is around 1.8"). Looking down the tube, it just looks like a massive diameter drop with the silencer. Add the volume displaced by water, and things are starting to get skinny.
So for a built 701, what is the smallest diameter exhaust you can run without affecting power? I figure Yamaha chose 2" (SN) for a reason, and Id hate to handicap my motor. (But then again, I haven't noticed any different outlets on the 1100cc boats? Even seen people pushing in smaller pieces to fix that left turn bog problem? :ugh: )
