SXR Tuning Question
Texan33
Yacht Wakes Hunter
Texas
Greeting,
I'm currently tuning my sxr for this year. I just installed a dry pipe and use the jets provided from Factory Pipe (152.5 main and 80 pilot). My sxr has stock motor with TBM flywheel and stock carburetors. I also switched the stock n/s (1.5) to a 2.0 because the pop off pressure was a bit too high.
The idling to 2/3 throttle is pretty much dead on. It's the high speed that is lean according to the spark plugs. I increased the main jet to 155 and the plugs is bit darker now but still a little lean. My sxr ran great and smooth. I couldn't feel any hiccups, hesitations, and load-ups during the test drive. It is just the high speed (2/3 throttle to WOT) that is lean. The spark plugs are brown-ish and wet from idling to 2/3 throttle (A little rich, but safe). 2/3 to WOT are light brown and dry. I have some 157.5 main jets and probably will try them out to see if that improves.
From my research, I noticed that several people up the pilot jets much higher than what I have in my sxr. Even some are higher than the main jets. I'm trying to understand why are they using bigger pilot jets and lower main jets. I mean the 80 pilot jets I have in my sxr seem to be dead on from 1/3 to 2/3 throttle. I understand that pilot jet delivers fuel all the way to 100% throttle but there is a difference between fuel delivery and fuel metering. I also know that if I want to increase the pilot jet, the main jet must have equal decrease to retain the same mixture.
I have a couple of 87.5 pilot jets lying around. But I'm not certain whatever to increase the main or increase the pilot ever since I learned of several skis with higher pilot jets.
Texan33
Yacht Wakes Hunter
Texas
Prop and nozzle are stock. The ski is basically stock except for TBM flywheel, Dry Pipe, and TDR waterbox.
I have been considering installing Tiny Tach into my sxr.
Scorn800
Ride for life
North NJ
So do you still have the choke plates in? aftermarket filter or stock?
Back in 03 I had dry pipe on stock ski and the ffp jetting was right on just tweaked the screws. This was with chokes in and stock air filter.
You might want to go back to 1.5 n&s
Texan33
Yacht Wakes Hunter
Texas
Choke plates are still in and I'm using Prok flame arrestors. I tested the ski out with the 1.5 n/s but I had better result with 2.0 n/s. The ffp jetting feels right on except for high speed part. I mean there is no hesitations, load-ups, or hiccups. It ran dang good on smooth water. I'm just cautious about the spark plugs in lean condition around 2/3 to WOT. I know spark plugs is not really an effective way for tuning. It will fire up no problem in the water without applying the throttle and idle pretty smooth.
