- new port richey,fl
I'm gonna be turfing my side rails here soon. Do put the screws back In that held the rails on and turf over them or do you leave them out?
fill teh holes with silicone or a filler. Helps keep water from spraying through and slowing working the turf loose. Sand the paint, get it rough, sand the back of the turf. 2 coats of glue.
Also, can you wrap the hydroturf all the way around the the backside to cover the holes and prevent water spraying through or is it better to cut the turf off on the bottom edge of the rail?
What do you mean 2 coats of glue? do you just wait to let the first coat start to set up but before it dries you add another coat? Also, can you wrap the hydroturf all the way around the the backside to cover the holes and prevent water spraying through or is it better to cut the turf off on the bottom edge of the rail? wanting to do this soon too, so any advice is helpful
Apply a thin bead of silicone, Take some WD40 or similar spray and spray on your finger, wipe up excess, this leaves a slick caulk line.
so just to be clear, I wait until the second coat also loses the glossy look before I put the turn down? what happens down the road if/when I need to returf? how do I get it off? I imagine that is going to be a royal nightmare
Does the surface need to be sanded before I turf or will the glue stick to the paint? If I can get away with not ruining the paint I would prefer that just in case I decide to go back to bumpers for some reason
