You always turf directly to the hull. Remove any existing padding or turf. I'm pretty sure the sides of the 650sx are originally vinyl covered foam with a plastic backing that is screwed to the hull. Remove the entire plastic piece. Fill the holes, and use hydroturf padding to regain original shape if necessary. Then apply turf.
