Other Twist Throttle?
Anybody ever tried it on a jetski? I was just wondering since all of the other two strokes I own (quads, dirtbikes) are currently running twist throttles. Not sure if it would work or not but lets hear what you think
btmboards
Brett
Oceanside, Ca
I think it would work not to bad on a fixed steer but not on a regular stand up. I ride everything else too (street, dirt, ect...) and the prob with having a moving handle pull is that the angle of arm to wrist to bars changes to often and to correctly manipulate that angle you need solid static grips.
snowxr
V watch your daughters V
Waterford, MI
Bad idea. A friend tried it years ago, and it made the ski very difficult to safely ride. Throttle control was nearly impossible due to the amount of movement between the rider/ pole/ steering/ waves. Even a minor slip where you might hold onto the bars, instead of letting the ski go would turn into a near runaway accident.
NorCal
I would imagine that it would be really hard to stay on the ski with a twist throttle...
say you half wipe out and are trying to just hold on and not totally bail... in the process you twist the throttle wide open... at best you end up totally bailing at that point. worst case you get a run away ski accident or fire hose to the nuts...
Schmidty721
someone turf my rails
WI
I plan on trying my trim on a twist grip this year. Right hand twist grip for trim, left hand finger throttle. If nothing else it'll be fun to watch people try to ride my ski
I like the twist trim idea. How come the twist would be on the right side rather than the left? The reason Im asking is because every ski, or quad I've ever ridden has had the throttle on the right, so wouldn't it be more difficult to get used to on the left?
Schmidty721
WI
Every twist grip I've seen is for the right side. You could mount it on the left, but then the twist action would be backwards.
I don't think switching the finger throttle to the left side would take too long to get used to, at least not for me. I think it would feel more awkward trying to operate a twist grip on the left hand than it would to use a finger throttle.
Waternut
Customizing addict
Macon, GA
I think the thumb throttle feels good on land but when you're riding and moving around, it's quite awkward IMO. With a finger throttle, you have your 3 most natural gripping fingers and a thumb keeping you from moving forwards/backwards when pulling the throttle or letting off. With a thumb throttle, you have have fingers limiting backwards motion but you're now relying on your palms and a severely bent wrist to keep you from moving forward. I don't know about you but that wears on my wrists pretty fast.
As for the twister trim...would those even give enough pull and leverage to accomplish the job? I've ridden some of the twist trim couches and thought they were impossible to use unless there was zero power. If you wanted, you could probably adapt one to a standup and just cut the notches out that hold it in specific places. I’m not that familiar with them because I struggle to even ride a dirt bike through any rough terrain without nailing the throttle by accident.
djraider700
lol wut?
South Jersey
My raider had a twist trim. Yank the little finger adjuster on the grip and mod the nozzle a little and it gives you a ton more throw.
I hate thumb throttles. It's a personal preference thing.
Waternut
Customizing addict
Macon, GA
What will?
When you twist a grip backwards you are putting your wrist at a 90° angle in relation to your forearm. You won't have any adverse effects from that alone unless you like to ride like that. The problem is, if you nose the ski in, all of your weight gets put on your hands/wrists and when your wrist is bent that severely and you put a ton of force on it, you're just asking to break it. The other problem I see is your grip isn't stationary so if you land with a lot of weight on your hands, there is nothing stopping your wrist from twisting the grip which goes right back to the first scenario.
