Hey guys,
ive searched in multiple locations, forums, threads, FB, you name it, haven't been able to get a solid answer. It's actually a two part question:
after riding for about 20 min, I pulled up shore to lift the hood to Check the hull. ( I recently replaced the head pipe to the coupler style, and also ran a new thru-hull pump fitting tube)
although the pisser was pissing normally, when I took the hood off after I shut the ski off, I noticed the motor was really hot, and the pisser line was extremely warm. No water was sizzling anywhere.
so I got it home and flushed on hose.
1) so, what is NORMAL OPERATING TEMP on the hose for a 650sx, stock, single cooled?
The front head area and cylinder were at 139*F and the rear head area and cylinder were between ONLY 92-97* F.
2) is it NORMAL to have such a difference in temps from the front cylinder to the rear?
Again, nothing was sizzling, but was super hot to the touch. The head pipe was completely COOL and so were the manifold areas and the rear cylinder.
just replaced the thru hull fitting/tube for the pump, so that is clear, pisser line and hull fitting are clear, both head pipe fittings are completely clear, air flows right thru, hose from head pipe to cylinder head is clear, air blows all the way through.
while making sure these paths are all clear, I took the pisser line off from the head pipe, and I saw this...this cant be normal...looks melted to me.
