Length wise it sits between xfs and fr if you put it next to an xfs and line the noses up there the same length but the bottom deck on the rear is the same as the top on overall where the xfs has maybe 6" of the pump exposed to give you an idea .
They were built as pure surf hulls and as such are extremely strong mine has been ridden hard by lots of people with no issues .
Few other bits of interest everything swaps straight over from Sj pre 08 accept it was designed to use gp800 mounts not Sj ( I have been using jetmaniac ones now for a while there the shizz)
built in front foothold,
Double hood seal system built into hood
adjustable footholds
through hull scupper starts next to the mid shaft housing ie the lowest point
thats most of it I will try and post a few more pics if you want
price they work out a little cheaper than equivalent rickter over here but im not sure how the taxes and shipping would affect you guys . Roughly $7800 I think but that includes out tax . I'm not sure if you would pay that or not I can put you in touch with the overall guys if your interested best to do it that way .
Finish is also excellent roman hakes pride in his work it's up the with the best .
I can almost flat water flip this off my own setup on my ported 701 with surf length pole and a shortened ride plate see pic
