Super Jet UMI POLE BRACKET QUESTION
IS0LD0UT
I hate winter
MN
Most of them are made out of aluminum, get some flat bar and make your own. I think they are about 3/16 thick, I can check my xmetal one when I get home.
IS0LD0UT
I hate winter
MN
An UMI one, no maybe ask @JetManiac. You probably could buy one for another bracket such as the xmetal one. The bolt holes are usually the same, the only difference is where the breather holes are positioned, you may need to grind them out to match up to the bracket.
