versiplug?
wydopen
onthepipe
I searched but didnt really find what I was looking for..
So versiplugs wern't around when I was riding before (that i remember) and I always used blowsions 1way valve in my other skis, no bilges....
Im not really worried about water leaking when ski isnt moving as I dont let my ski sit in the water...
Im assuming the versiplug would allow more air to escape when the ski is upside down than a 1way valve or scupper? unless the bow is pointing down it would basically be a 2" gaping hole?..at least with the 1way the flap is still partially covering the opening when there is no pressure on it..
So for people running the versiplug max does your ski sink quicker than with a scupper or 1way?
Thanks
Tuscaloosa, AL
If the Blowsion setup worked, go with it. I had issues running only a Versa plug max on my Edge with the scupper flap removed. Sucked in exhaust. Not a fan. There are some who have had good luck with the Thrust setup.
