- Alabama
SOLD
-2 glass/CF reinforced ski. It is a 2009 Wamilton’s hull, not a superjet built by Wamilton. This ski was owned by a 60 year old lady (seriously). If it has more than 15 hours on it, I would be surprised. It is a super clean ski. It has the factory finish on it from Wamilton's
It has a Jetworks 5 mil stroker with 82.5mm pistons, putting it right around 800cc. When I acquired it, I sent the complete motor out to Art at Jetworks to be freshened up because it had been sitting inside since 2014. Art went through the whole motor installing new crank seals, pistons, rings, and freshened the blackjack 46mm carbs up even though they looked brand new. It's got an RRP pole, RRP steering, b pipe with polished Mod chamber, msd total loss with multiple chips available to use, blowsion handlebar bilge pump switch, Thrust airplane style fuel filler, and new Deka battery
I just installed the motor and took it out for an hour today to seat the rings and make sure everything was good to go. It didnt miss a beat and is definitely a rocket! I checked compression when I got home and it was 185 a hole (I told Art I did not want high compression domes). This is one fun ski! 11,500 obo
