FX-1 Washer on drive shaft before impeller?
Dirtybird
Ex*ta*ski
St. Clair, MI
Just put a bearing kit in my fx1 pump , screwed the new impeller on and it bottoms out before it tightens on the shaft.
What am I missing?
Received the pump and shaft in pcs so might be missing a spacer, washer?
Thanks
58vwragtop
Braap Certified
Blue Springs, MO
Also make sure the drive shaft is pushed all the way in where it suppose to be. I ran into this problem and found my shaft needed to be pushed in about a 1/4"
DangerBoy
Runs with scissors
Rincon Beach
What am I missing?
Thanks
Sounds like you are missing the spacer between the seals and the impeller
62t-51348-00
Db
