Hmmm... I do not have any washers at all.
Is that bad?
It just determines how far the impeller is from the vanes. You can adjust "cutback" that way.
On my 140 Mag, a spacer is actually necessary because the impeller that was ordered new from Skat Trak was so far cut back that the hub would rub the stator section without a washer.
My 140 is exactly the same - I need 3mm of washer just to allow the prop to clear the static vanes
