Other Water in ebox?
DC KS
I'm chasing a gremlin in my blaster. It seems that once something gets wet it starts sputtering and cutting out only on the top end. I pulled the ebox on my blaster to change the coil and there was a good amount of water in it. What's confusing me is I cant seem to find how water would get in there? The seal looks decent and I tightened the screws as much as possible. Is this common or is there anything else to check?
OCD Solutions
Rentz, GA
The grommets can leak a bit, especially around the battery and starter cables. Was the cap screwed on tight?
Does it look like it was in there for awhile?
DC KS
The cap is tight. How can I seal the grommets? I wouldn't think they would leake enough to cause problems but who knows.
Some of the screws show a little surface rust but other than that I can't tell.
