astrokawasaki
KrashesAlot
- Nsb, FL
$4000 RTR
$1200 Bare hull w/ pump shoe, can add whatever components
-Made by WCF In '01
-SN bottom angle cut -3
-Custom Top deck made by watercraft factory, widened tray
-Glass hull completely carbon fiber reinforced
-Widened carbon fiber rails
-Bolted front sponsons
-KP Pole w/ visual carbon chinpad.
-Cold fusion turn plate
-Riser bars 40mm rise
-Bilge
-Thrust EZ drain
-stock pump
-post 08 sj prop
-62t/61x SBT 701s Superjet motor (warranty til 10/19)
-single 46mm team scream carb
-reed spacer
-Bpipe
-TDR waterbox
-Reconditioned 61x stator and flywheel from Jetmaniac (purchased after Daytona Freeride)
Gets ridden almost every weekend.
Test drives available.
More pics and videos upon request. Have plenty of onboard gopro footage.
Thanks for looking.
Pwc. Tigercraft. Waveblaster. Super jet. Rickter. Yamaha.
-Made by WCF In '01
-Bilge
-Thrust EZ drain
-stock pump
-post 08 sj prop
-reed spacer
-Bpipe
-TDR waterbox
Thanks for looking.
