Wave Blaster wont start
Hey guys,
My Blaster wont start, when you press the starter, it sounds like an old door opening.......CREEEEEEEEEEEEEEEEK
But nothing happens, battery is fine, any suggestions?
Thanks
Wisconsin
Does it sound like the starter is spinning at all? If it is the starter bendix are pretty common on yamaha platforms.
Sent from my SM-N970U using Tapatalk
If you can turn the motor over by hand, my guess would be bendix.
The only other thing that would make a creaking sound would be if the wear ring swelled up and is touching the prop, its easy to shine a flashlight into the pump and see if its touching anywhere.
