Waveblaster oil delete
MN
What are the steps to block off the oil injection? I recently picked up a 94 waveblaster and wanted to just run it pre mix. I am still fairly new to all this so I assume it's pretty straightforward but I couldn't really find any walkthroughs online. Do I need to drain all the oil out first? What's the best way to do that?
Thanks!
Mike W
Infidel
North Florida
Easy. Fill the gas tank. Premix the gas with 50:1. Hook up the flush kit. Start the ski. Turn on the water. When it smokes more than normal. Shut it off. Install block off kit.
WFO Speedracer
Alabama
Remove the oil tank with the lines and the oil pump all still attached , install block off plate ,then do what Mike W said.
