WB high speed problems
I have high speed "bogging out" issues w/ two seperate blasters.
- single carb ski completely dies @ full throttle.
-dual carb ski bogs out @ high speed.
i have not cleaned out the carbs yet. i have not seen any water in the gas or lines. I'm assuming the carbs need to be taken apart & cleaned, but i was hopping for a simple high speed carb adjustment to be my answer...... i'm sure it isn't that easy. possibly to much gas @ high speed???
thanks ahead for any help.
tom21
havin fun
clearwater FL
one time I had the high speed check valve(little plastic flap) fall off due to the screw breaking.
on the dual its sound like you may want a new needle and seat on both carbs. do not replace the oem springs! leave the ones that are in there.
i'm going to clean both carbs & see how they run after that. if i still have issues, i'm thinking of turning the high speed screws in 1/4 turn.
Are you still selling the tubbies & hood for an x2?
Thanks for your help & ideas. very much appreciated.
