WB1 Side Mount Help.
WaveDemon
Not Dead - Notable Member
Hell, Florida
when I learned I was about 240 lbs. i'm about 6' though
get next to the left side of the ski and keep your body vertical in the water
lean it over, start it, and hold the steering to the right
give it some gas and start leaning it back up straight (keep the steering to the right)
when the pump starts to hook up give it some gas. as it starts to take off put your right knee or foot on the rear deck.
pull your self up and straighten out the bars.
if you can't get the pump to stay hooked up you aren't staying vertical in the water long enough.
stuntbikemike
Time to ride
clearwater
plus on the flatwater mounting from the rear is easy.......in the surf is where it counts.....keep your body up as close to side without tipping the boat......than gas it to get up
