WB1 wont rev turned full lock
88kawi5fiddy
pew pew lazers!
So Utah
IDK i have a theory, but anyone else had this happen?
new b1 i put together and rode today runs frikkin great. a little weird jetting off idle, but not every launch.
now: during hard turns after WOT straight, turn bars, pin it, motor bogs and wont really climb RPM. turn bars straight, instantly revs out.
is my nozzle eclipsing the reduction and just straight up cant push water?
82mm (i think) 62t reduction, trim ring and whatever stock plastic nozzle is on it. I swear ive read this happening to someone before but cant find it.
Alabama
I remember two threads, here they are.
Here's one.
Here's the other.
Is it still running the original crank? My 97 GP 760 does this because the crank bearings are fried. You can't move the crank inside the bearings by hand but both G force in hard turns and the power stroke are enough to push the crank out of true inside the bearings opening up an air gap between the crank and seals. It causes a very lean condition by drafting in quite a lot of air from the crank seal leak drying out your base and giving you the "bog" effect. A quick check you can do to test if your bearings are worn is if the coupler off the crank is getting hot. I actually burnt my finger on the GP coupler it was so hot. The bearings are so badly worn it's creating a lot of friction inside the races. My SuperJet goes through far more abuse than the GP and I can get my hand on the coupler right after stopping for a break without concern.
88kawi5fiddy
pew pew lazers!
So Utah
Here's one.
Here's the other.
Aha! I have a trim nozzle setup and stock pump exit exhaust. I can almosy guarantee that its pushing too much water into the exhaust
