Hello,
Looking for some help!
I was getting the classic click when I hit the start button on my 1997 WB760. Pulled the starter and it was toast. So I replaced my starter and starter solenoid and when I went to start it I hit the start button and the starter ran until I disconnected the battery. So I then took apart the start/stop switch and cleaned it and tested it to make sure it’s working correctly per the manual and was so I tried it again. Now once I hook up the battery the start kicks on instantly. So I double checked the new solenoid is good and it checks out. I’m getting frustrated with it now. Any idea what would be causing the starter to just run it the starter, solenoid and start/stop switch check out as good?
Thank You,
Luke
Thank You,
Luke
