WBW Ebox Enclosure
Www.weeksbrothers.com to order or DM me here or on socal. 2 drop ins left and 5 relocation bixes just released.
Excited to show off our new yamaha ebox enclosure. Limited testing so far has shown some great results. i tested 2 units at daytona with lots of flops and tried to beat them up as much as possible. Both Units come with a unique color indication silica desiccant and a perfectly fit holder for them to provide a moisture free environment. For once in your life you will want to have blue balls all the time! Silica turns clear/ pink when it has absorbed water to its capacity indicating that your ebox has a leak or needs to be resealed. Silica is reusable and can be dehydrated in your microwave or oven for reuse. We also have done some complete submergence testing of the box and found that both a stock box and ours needs a small amount of 1211 or similar sealant on the face of the Grommets where it meets the gasket. I also like to put some where the wires go thru to fully seal the box as well. I was walking around with one at daytona showing it off, so maybe you saw it there! 1/4" thick lexan is super strong. Ebox side plastic is made from an engineering photopolymer resin which is super tough, passes drop tests and has to be smashed for it to break, it is also paintable. All Stainless hardware with lock washers to make installation easy.
I have a Drop in box which will be for those who want to retain the solenoid wires and will be a stock drop in replacement (This does not have the relocation for the solenoid wires)
I also have a Solenoid relocation box which will include all hardware to relocate your solenoid terminals outside the ebox similar to the JSS kit, but fully integrated into the design.
FOR SALE - I will be selling 5 "drop in" units to start (i have 3 left) at a discounted price to get them out there and have some more use before releasing them fully.
For $135 shipped you will get everything you need to replace the stock plastic enclosure - Lexan glass, hardware, silica holder, silica beads, 2 OEM gaskets, new JM grommet wired with a external fuse, and an ebox side housing. After some more use from these 5 units we will release some more units at a higher price of $175 shipped. (this is a direct replacement of the stock box, NO relocation kit) - Shipping Mid February -
Relocation boxes are still being worked on and will be ~ 50$ more than the drop in units once figured out fully. (most of the pics are of this unit as it is more complicated to install and the drop in is easy)
Bonus - New retainer for 760 ebox Zeel installations (see pics)
Thanks again for all your support! Let me know any questions, comments, concerns! - We also offer a full ebox build service if thats something you need. We have 1 MSD and 2 Y62T Zeel on the shelf as well for sale ($399 each) and able to get 760s zeels as well!
Dave
Very nice looking and great idea with the silica!
Thanks man. after having a ~2 Yo built ebox totally melt down a stator harness i had to do something better. Need to be able to see my Electronics and know when it is compromised - i have another idea for further protecting it that can be added on, depending on how long my blue balls last.
Crankin Customz is dipping some boxs for some builds coming up. looks really sharp - Fully paintable - i also Painted one up with a baby blue for my brothers SN SJ build coming up - Keep your eye out - This weekend they go on a special spring sale! - Hit him up if you want some color in your life - he does awesome work!
Thank you Chad!
